Travertine & coffeeeeee
Shorty
Cairns
Shorty Glanville
Relatively new apartment block has travertine kitchen tops.
They also have a large domestic coffee machine on it.
Coffee has spilled onto the travertine and stained it.
Can someone describe the method to restore this please ncluding all materials.
Thanks,
Ooroo,
Shorty.
:roll: :roll:
Gary T
Why do people do this stupit crap.
You'll need a poultice. Usually DE(pool filter media) mixed with a solvent or rubbing alcohol til it is pastelike. Cover w/plastic and remove after a day. Repeat if needed.
You'll also likely need to remove the etching with diamonds and re-hone or re-polish it.
You can seal it, but that will not prevent etching. A nice piece of glass to cover it will work.
When you are done, break off a large piece and beat the salesman over the head with it.
If it were me I would use Diamatious earth and 40 vol as a poultice.
Slop it on good and thick, cover for 24 then let dry. Repeat as many times as needed.
C
clean image
like mikey said
your gonna need HP for the tannins
refinish with twister
carl
