Hoody
Richard, Steve G, Bill and others...
I've been on a lot of jobs whether employed through a company, or private contractor where we/they were using air scrubbers and or AFD's to clean the air. I've noticed a majority of the time there wasn't enough equipment to perform those tasks properly. A lot just want to get paid because they put the piece of equipment on the job because they know it needs to be there. But many don't really know what's needed/recommended for each situation, or how to calculate that.
Remind the class - How many air exchanges an hour are needed/required during different situations. Cat 2/3, mold, smoke and fire.
For anyone reading that doesn't know how to calculate that.
Say you own the HEPA 500 by Dri-Eaz. The unit pulls 500 CFM. 500 x 60 = 3000 CFH(cubic ft per hour) If you have an area that is 10x15x8 it equals 1200 CF. If your situation called for 4 exchanges and hour. That means you'd have to cycle 1200 x 4 times making that 4800 CF. Your one HEPA 500 wouldn't be efficient enough to perform that task. You would want to add another unit, or use a larger CFM unit to perform the task.
Is there a general rule of thumb that 4 exchanges an hour will work best? Are there times where we need less, or more?
Has anyone done any real world testing if different filters affect the perform of these units ?
Since the IICRC is pushing the use of AFD's in most every situation. I thought it'd be a good topic to bring up.
