Vid of the Devastators
L
Lumber Jack
I just want to show you guys some vids. The first one is from today. I prevaced and filled 2 bags. The carpet was full of stuff so pre vac had to be done. P Management pays good money if I can save the carpet. The video is not about the carpet but is just showing how much debris I put in the filter and how CFM stays High more cfm the more stuff is going to come out. I did use Roto due to the deep down soil. This was a small 2 bedroom apartment.
This one is with the Mini Devastator same deal see if you can save the carpet.
Just want you guys to see how good they work.
L
Lumber Jack
I have a pro chem legend #4 mvl blower run 4 2 door with 14 -15 hgs with wand on the carpet. I can pull throttle out more if I want more right now I'm running 3100 rpms can run at 3600 and probley get over 400 cfm. I have done a few mods.
Its been a lot off fun I only had 190-210 cfm stock. I even have better heat now too. What machine do you run? Do a few mods it really makes a difference.
Never Mind you have the TM I look up to jeezohh.Someday maybe :D
