- Joined
- Oct 9, 2006
- Messages
- 64,833
- Name
- Rico Suave
I'd watch your dollars as it begins to creep up there you'd be money ahead with a TM, even if it's an electric from Mytee or Terry Brevik.
So. I am still curious about the steamin Demon since they have endorsement from shaw ind. and have the gold seal of approval from CRI.
And has anybody used the CFX from Rotovac,
Erskine Allin said:So. I am still curious about the steamin Demon since they have endorsement from shaw ind. and have the gold seal of approval from CRI.
plenty of polyticz involved in the whole seal of approval thingie .
It's all horseshit anyway, cause a good or bad job is 99% contingent on the operator's skill and knowledge ... not the equipment
as far as the S-Demon, it's bad enough being tethered to cords indoors .
Now add water and drain lines .
not to mention homes and empties with multi-level floors.
Disconnect, carry all the chit upstairs, re-connect ...fck all that
with a porty, you can leave it at the bottom of the stairs and just add a length of vac hose and solution line .
The Demon is an "OK" machine for some applications , but a porty and wand is far more versatile and just as good for cleaning
[quote:1hcwbfhr]And has anybody used the CFX from Rotovac,
Yea, I scrambled it in there. Rookie mistakeLee Stockwell said:Best to keep your reply OUTSIDE the quoted area, either before or after. Hard to distinguish otherwise.
Portables have similar freezing issues to TMs, unless you bring them inside.
It is true that I am a rookie who has never even cleaned carpet.
Multiple power cords create an electrical spaghetti mess, coupled with bucket brigade of dumping and filling. In the end it's just low power when compared to the heat and vacuum a TM can generate. I personally would rather use OP or a Cimex if I can't use a TM.I was surprised to hear some of you look down on portables.
