What am I doing wrong?
Discussion in 'Hard Surface Hub' started by Chris Brown, Nov 26, 2017.
  1. Chris Brown
    Chris Brown
    Apr 2, 2016
    48
    Sacramento CA
    Name:
    Chris Brown
    I need advice on polishing carrera marble counters. I have been practicing with mb stone ultra turbo 4 inch pads, 50 grit-1800 grit. Then stone pro emp powder polish. I'm having problems with the edges. Everything looks good except along the edge where I stop the machine. I'm using a makita variable speed polisher. The final edge still looks dull and scratched. What technique can I use to eliminate this problem? Any suggestions would be greatly appreciated. Thanks.
  2. SamIam
    7,529
    Name:
  3. SamIam
    7,529
    Name:
  4. SamIam
    7,529
    Name:
  5. Cameron DeMille
    Cameron DeMille
    Feb 5, 2013
    527
    Southern California
    Name:
    cameron demille
    first of all, eliminate the 50-120 from your process. Unless absolutely needed, for severe etches and deep scratches, 99% of the time you will start with 220
    When you do counters, you need to hang 30% of the pad over the edge, like you're overlapping into space. If you just bring the edge of the pad to the edge of the counter, it will never look right.
    So try that, 220-1800, bring each grit 30% over the edge of the counter, then polish.
  6. Chris Brown
    Chris Brown
    Apr 2, 2016
    48
    Sacramento CA
    Name:
    Chris Brown
    Thanks Cameron
Share This Page
