Who uses a thermo valve?
icleancarpetz
Rafael Samson
Cat pump thermo valve or similar.
Do they work without fail?
Does it cause water dump without interruption to your wanding or is there a delay of a few seconds pause until the hot water is discharge?
icleancarpetz
Rafael Samson
They should fail at open, which means you will see a constant discharge to your recovery tank, unless your unit diverts it elsewhere.
so if the unit does divert elsewhere, the thermo valve should only become active if that the first (diverter) source fails.
Is that correct?
MLPW
Georgia
Is that correct?
The thermal valve should be plumbed to be the first diverter source. And like Jim said, when it fails, it just remains open and your recovery tank will fill up much faster, only affecting the lack of heat in the machine.
Which specific truck mount are you working on?
icleancarpetz
Rafael Samson
I’m not allowed E to Z list the name 27 the machine 47 cause it violates the King Willy Wonka Mikey bylaws enforced by the Oompas.
  • Haha
icleancarpetz
Rafael Samson
I do have a Johns hot heat exchange ss bypass diverter box I bought from John years ago. One of the best purchases made for my lava hot volcanic heat producing machine with a #4 blower that will suck your entire body into the waste tank if I don’t have my seat belt clicked.
So with this thermo valve, thought to add a little more protection for the pump.
Redding
Yes, I use one. The stock on that Sapphire puts on their TM's is a 160 degree. That thing failed all the time. I finally changed it to a 180 degree years ago and have been problem free ever since.
MLPW
Georgia
Is your 870 the plastic water box or the metal one under pressure?
Redding
Reactions: icleancarpetz
