Zipper wand
Congrats Matt. Once you get past the learning curve, you'll love it. I had my helping me on a job today (and she thought she had a day off). We were doing apartment hallways. There are 3 identical buildings in this complex. 3 hallways and 2 sets of stairs each. I did the first building by myself with the Zipper and it took 4 hours. With my wife handling the hoses (300 feet) we finished in just over 2 hours. Last year I did it with the wand and each building took 5 hours. Not only is the Zipper faster but I am cleaning the carpets much more thoroughly. I am flushing both forward and back and then doing a dry pass. When we are done, the first hallway is allmost dry. By yourself, in narrow hallways, the Zipper can be a pita because of the hose mgmt. But you have to do the same with a wand as well. With a helper, you will fly through commercial jobs.
Grand Rapids, MN
What are the options for the Zipper?
How often do you have to adjust it?
Rarely adjust it...
Options:
13 " with five jets for 5 flow, 7.5 flow and 10 flow
15 " with six jets for 6 flow, 9 flow and 12 flow
SS super spinner for 4 flow (but really higher in water put out with psi) and 6 flow
Handles:
Regular straight T handle
Tall Boy ergo (looks like a Z) handle
Colors: A few colors floating around but Gun metal Grey (which won't show scratches) and Blue
realclean
Bossier City, LA
Jesse Lowe
Thanks Mark, I did not see any of these options on the site.
Now I think as much as it cost I will need a case for it, or just strap it in the passenger seat!:rockon:
Reactions: Mark Saiger
Grand Rapids, MN
Forgot to mention he makes base plates that bolt to the floor to hold them safely too :)
And glides it will come with a hole glide in the back, and slot typically in the front.
We also have hybrid glides for the front for those really bad cheap olefin carpets we will run into occasionally
Prattville, Alabama
I have gray too. That shit just never looks good after use. It serves a purpose as a moisture/rust barrier but appearance wise I'd just as soon have carpet over plywood.
At least when the carpet looks bad you can just recarpet. Plus its a nice flat surface, easier on your knees.
Reactions: hogjowl
