Prochem Procaps detergent
CleanEvo
Has anyone used Prochem Procaps... not the CRB machine but the encap shampoo called Procaps?
I'm almost out of Releasit DS, which I normally use for encap with a Cimex. I can get the Procaps locally to tide me over until I can get more Releasit in. I don't think it foams like Releasit DS, so will it work with fibreplus pads?
I can also get a product locally from Esteam called EncapEBC.
Has anyone used either of those products in a Cimex?
randy
Randy
I have used the Prochem product and don't care for it , however I have used it in a pinch and would again. It will work fine with fiber plus pads.
ACE
Mike Hughes
I was not impressed with the procaps stuff. It’s PH is too low for anything but wool IMO. I use the Interlink stuff most of the time but may switch to vacaway after getting good results from the samples.
I'm sure that Releasit is a fine product, but I use the VacAway product line because they have an encap product for every imaginable situation. Including spotting.
CleanEvo
Thanks guys, I'm in a bit of a pinch so have to get something local. I'll have to try the procaps on this one. Can I boost it with anything that won't change the chemistry too drastically?
Jesse
Procaps is very lame, you might as well use soil crystal rinse from cti (not recommending that).
I would use any encap product before prochem/windsor
We've used the esteem in a pinch, I can't really remember much about about it so it couldn't have been as disappointing as procaps.
I'm using it with my cimex and I haven't had any complaints
