APO for waste tank...
most "low cost" option I know of requires 110vt power supply....AKA, an extension cord
you can plumb in a regular ole sump pump.
If you don't use a an inline filter to strain carpet lint, use a sewage pump
a top quality pump costs around $200-$250.
Mics plumbing and fittings will run around $50 or so
couple/few hours to install
Pump, 1.5" PVC and check valve inside the tank.
Conduit for outside and thru the tank plumbing.
end of conduit gets a 3/4" male pipe thread fitting for garden hose hook up
(use 3/4" commercial garden hose for discharge hose)
the water level creates a barrier and the vacuum does not effect them......
Blue Monarch
Dirk Wingrove
Why are they all so damn expensive then? Mine got all wet and the motor died....been without for a coupla years. Would love to build my own, but really don't know how to go about it.
BILGE PUMPS...thry're made to be submersible....24/7.........
Blue Monarch
Dirk Wingrove
Somebody could do good by making a foolproof (read, dirk can do it) tutorial on how to make an apo.
Able 1
Keith
I have that APO from the unit I bought from Ben make me an offer... I have it ripped apart right now, but I could rebuild it or you could do it yourowndamnself and save some money?
