Propane Powered Portable (truckmount style) ?
PCCN
Does anyone remember the "portable" propane powered truckmount style machine that was out a few years back (Hydramaster I think)? It was mounted on a small cart. Just wondering what the model name was and if there are any still around. I do a few highrise buildings and this might be a much better and faster solution than using a porty and lots of help. I use a great heated machine now but if there is a larger machine as that propane powered still available I would like to check into it.
cu
Cu
i think i would look at the mytee etm
PHILIP NICK
They built a portable version of the Boxxer 421 with propane fueled motor. It was green and had the tanks under and behind the unit for solution and waste.
PCCN
This seems like a good option but electricity if the issue as well as power. In one highrise we clean a few times a year the breakers throw very easily and we have to take a secured elevator to the main floor, wait for the roving security guard to come down and escort us back up to the floor we are working on, just to reset the breaker. (They can't leave the elec. room open because of alarms on the doors.)
I actually looked at a Bane porty a few weeks back thinking bigger capacity and better suction with their #3 blower. It has no auto shut-off for the waste tank, no fill ports, a modified heater coil inside the fresh water tank, only does 170 PSI (non-adjustable), and still takes 2 power cords which is one of the basic issues. To beat it all, $7.495.00!!! HELL TO THE NOOOOOOOOOOOOOOOOOOO! I fell off the truck but not yesterday! :)
Andy McFadden
DO a search on craigs list, I saw a couple for sale awhile back. was tempted to get one for $3000 , it only had 150 hours on it. The other one had very low hours too. Search "hydramaster cm 302" Then try cm 402, use craigslist crawler or similar
boazcan
Bryan C
What about the butler portable? Pricey but hopefully could do tile. Anybody ever use this or seen it in use?
PCCN
I saw one when I visited their office a couple years back but then again it is electric. It would be absolutely perfect for my use if I could get the power. It gives great power (suction and PSI).
My pops friend Al Casas had a CM402... My pops also looked into buying one but went with the workmasters... Al said he had a lot of problems with the propane motor. So he just put an electric motor on it and made it a shop TM...
PCCN
Thats good to know. Maintenance is a huge issue, especially for a machine that they dont make anymore.
