Ron K
- Jan 3, 2009
- 2,371
I have a Legend XL 1800ish hours on it and I have just recently noticed water coming out my exhaust while running. Worse when cold less when Hot.. Is it time to raise my prices???
If your not soaked when standing in front the heat exchanger is fine. What has been your outside RH? It is just condensation Prochem allows for up to a cup and hour so don't stressBriefs just a little yellow, in the front. But the machine just seems to be dripping through the exhaust maybe 1/2 to 2 teaspoon. Something I've never noticed before in that amount.
Whats the diagnosis.... beside new panty's.
Heat is ok I used to have a Mastermatic and nothing compares to that. In the summer heat is ok winter time so-so. Takes a while to get up to temp and recovery is slower. Just had it serviced they didn't say the coils were bad. I do shoot wd40 every once and a while but not daily maybe actually once a week tops. If it is condensation though why has it just started happening lately we've had it over some time and I am very conscious of any fluids leaking anywhere in my customers driveway.
How often do you guys clean off your heat exchanger fins? My unit doesn't use this type of exchanger but I've seen some get real dirty. I would think the older the engine the worse it can get, especially carbon build up.mine did not seem like it did it at first either....I put WD40 in mine at the end of every week....after a while it will start to leave a trace on your coils/fins......your heat sounds like it is doing fine.....same as mine...in the summer it is cooking...in the winter months it takes longer to get to temp and I lose about 10 to 15 degrees....personally I really don't think you are having anything to really worry about...maybe a bit of build up but that's about it....
why they did not condensate so much in the beginning ...is hard to say.....there may of been an oily coating on them when they were new and in time it burned off...???...or it just could be build up and holding moister....what ever the reason....I still think your OK...
another thing......and this does not have anything to do with your coil...you will start to notice that as it gets colder..you are going to have o-rings dripping......after they wear a bit they will get hard in the winter...as your machine heats the water up they will normally soften up and seal themselves....another one of those things that happen when it gets cold....only worry about them if they still drip after the water has heated up.......
Been running for a while now and and more water is coming out for longer duration too until it stops. Also now water is just leaking out at night. I have an appointment to hav e it repaired should I ask for the old one back???
