filling the hydro force with powder
floorguy
Doug
So as I sit here waiting on a key.......
What do you guys use to fill the hydro force when you put powders in?
I have a slightly larger funnel but even then I have to poke it through...kind of a pita
Charlie Lyman
Charlie Lyman
Cut the top off of a 2 liter pop bottle. If you lose it, no big deal.
T
TimM
Doug, this is what I use
you can get it at any auto store
www.priceisrightcarpetcleaning.com
joey895
Joey J.
No funnel for me, I just dump it in the Hole with the 2 ounce scoop that comes with powermax.
I'm using the Mytee 7 quart jug though, maybe that helps?
Sent from my Galaxy Nexus using Tapatalk 2
You can't be serious Douglas! Mix the powder with hot water before pouring it into the HF... :clap: And to think, you had the nerve to talk crap about your buddies Joey and your good friend who runs his Apex on anything but high... :icon_twisted:
Goomer
Frank Mendo
Sophisticated porty-hacks prefer to pre-fill a few 20 oz Gatorade bottles with powder.
Stick the Gatorade bottle neck right into the hydroforce and spin it to empty it.
To fill the Gatorade bottles, I found if you cut the neck off a Poland Spring 16oz water bottle, it will fit perfectly inside the Gatorade neck and even stay standing up so you can scoop right into it.
No poking required, as a little jiggle will usually do it.:lol:
BLewis
Billy Lewis
I use the newer jugs that have bigger mouths. Then I just pour the powder in with the 2oz portioning cup supplied with most chemicals. Then as I fill with Hot water from the fresh tank I shake it for the first 1/3 of the jug fill. I have never had a problem with any powder mixing.
S
steve frasier
hydroforce has a new 7 quart jug with a removable cap on the back, before that I used a funnel
oops, just read Billy's reply, same as Billy
A canning funnel made for filling quart glass Mason jars.
I "borrowed" my wife's and have it tied with a string next to the Spraymaster hanger.
However the funnel is for the boys, I just use the product scoop. The secret to doing it with the scoop is to put the entire scoop INSIDE the jug before dumping it= no spillage.
Ron Werner
Ron Werner
I use the big spraymaster jugs. I can either put the powder directly in the jug or I have a 2gal wide mouth jug I premix and pour from.
floorguy
Doug
:clap::clap:
all good ideas....and I do have the 7 qt bigger one...then i never take the valve part off...And I just bought one of those low profile bigger ones...
hate using the damn 2oz scoop....plus like Lee said above.....
I like the premixed gatorade idea though...hummmm
i just cup my hand around the mouth of the jug and pour with the other one. but i stopped using powders in my hydroforce. havent had it clog since. now i use a 2 gallon pump up for powders.
A
Able 1
I mix in a 2 gallon jug like Ron, and pour it into the HF jug all mixed up already. The nice thing about doing it this way is you can add the booster of choice for the what ever your dealing with right to your HF.
I
idreadnought
I use a 20 oz gatorade bottle that is pre-filled and pre-measured with cleaning agent to fill them. at the shop I have a scoop that is 12 oz and a large funnel to fill the gatorade bottles with. It is fast accurate and saves lots of room in the van that would be used up with larger containers.
G
GreenTechAgain
Take whatever your pre-mix ratio of power is make several zip lock sandwich bags full.
Cut the corner of the zip lock bag off and pour into container.
Lot easier and more accurate.
Reactions: dealtimeman
