What's in your emergency tool bag?
Lisa did a fantastic list about 5 years ago but I can find it here... Fred?
anyhow it's always a worthy topic.
Plenty of QC sets
Teflon tape
assorted brass nipples, reducers and elbows
a couple spare pressure hoses
O rings for QCs, Dema valves, triggers pins etc
a few Westpak wand valves and rebuild kits
Hot glue gun
all sorts of tools, hammers, pry bars, screw drivers, wrenches of all types
Knives/razors
First Aid kit
Fire extinguisher
Flashlights
yellow police tape
blower, pump and engine oil
tarps and runners
manhole lifter
fuses
electric tape and wire nits
assorted screws, nuts and bolts
Jim Martin and Lockhart's phone numbers on speed dial
TP
pH tape
assorted scissors
electric cords
spare vacuum belts/filters
pantyhose
extra cool cuffs and adaptors
this is all off the top of my head, I'm sure If I went out and looked I'd find 20 more things...
what else?
Johnny
Johnny
Jumper cables (20', heavy gage). Long enough to reach from van engine compartment to TM if you leave the ignition on overnight or to aid a damsel or brudder in distress or start a derelict vehicle to get you better access to a job.
Hoody
Steven Hoodlebrink
Years of Experience
20
Had to do that last week to jump my TM.
AshleyMckendree
Ashley Mckendree
air Impact wrench, and 30ft air hose hooked up to my Co2 tank to change flat/blown tires in less than 2 minutes.
Duckbill scissors.
Carpet owl
white out
A hand pump sprayer (for those who use mainly the HydroForce (mine collects mildew somewhere in the van.)
Ron Werner
Ron Werner
they just need to invest in better tires!
Police tape???? I've never needed that in 20yrs. Is that common in your area??
S
Shane Deubell
We always use caution tape on floor waxing jobs, not sure if you guys meant the same thing.
rick imby
Rick
A cooler with a Six Pack of whatever
Edit: Link removed.
rick imby
Rick
How about a Battery Jump Starter instead of Jumper Cables. Mine has a little air compressor also. I charge my electronic toys off of mine also.
SMRBAP
Anthony
Only listing what hasn't been mentioned.
- Mechanical hose ends and a dremel with a cutting wheel. 5 minute fix for black death in the field, only works if you use neptune or the like.
- easy outs to remove broken nipple ends
- demand pump fuse
- 2 ft of weather stripping to temp patch waste tank lid seal
