gimmeagig
- Mar 25, 2007
- 744
- Name
- Roxy
Hi,
I just bid on a commercial office job.9 rooms which are carpeted and a small kitchen 5X8 and a bathroom 6X10 which are vinyl and need to be waxed.
I really wanted the job and I didn't want to loose it just because I am not a hard floor guy.I was honest with the client and told him that I have not done vinyl and that I would check first before I commit to that part.He knows the work I do as a carpet guy so he trusts me and gave me the go ahead.
I went to my local supplier who used to be a janitor to to find out how to do it. I do not have a rotary machine and he said I wouldn't need it for such a small area.
Here is what he set me up with.
A 8" scrubber for a broom handle with 3 pads, white blue and brown which is the coarsest.
one gallon of Franklin Offense fast acting no-rinse stripper.
one gallon Franklin Interstate 50 self sealing fast recoat variable UHS floor finish
Another 8" attachment for that broom handle Lambs Wool for applying the finish.
He told me to pour the stripper gradually out onto the floor and scrub it with the coarse pad, then use my carpet wand to rinse and extract.
After that, to stick my blowers in the rooms and once dry to apply a thin coat of the finish, let that dry, but not use the floor driers because of dust and ripples.After 30 minutes another coat and possibly a third one after another 30 minutes.
Does that sound right? Is there anything in addition to that that I should know or be aware of? Like I said I don't have a rotary scrubber and this is the first vinyl job I have come across.
Also, I was not sure what to charge for that. I got the right price for the carpeted areas and because I didn't really know I added 80.- for the vinyl areas.I assume if someone would do the vinyl separately it would be more?
...they are better for getting corners then the foam ones..... little lighter and easier to maneuver around toilets and such....
...just trust that it will fill in and look ok...
