does anyone shampoo upholstery or rugs anymore?
juniorc82
Jon Coret
I had a sample of jon don mirage upholstery shampoo. Decided to clean my microfiber sectionial at home with it. Whipped up some foam with a natural sponge and applied and aggitated with a horse hair brush. I rinsed and extracted some of the areas with all fiber rinse and the spotter. Seemed to come out really well. I didnt really see an advantage to doing it this way , it didnt really seem that efficiant. I havent tried using the shampoo method on a rug. Are there any advantages to using the shampoo method or is this simply a time machine kept alive by the older cleaners memories of their glory days lol?
We use it often on special care fabrics, older materials seem to respond better with other methods. HWE cleans them better but can cause some browning on natural fibers. Shampoo with a horse hair brush or sea sponge give you better control in awkward spots like arm fronts and piping and trim.
Reactions: Jeremy
Hoody
Steven Hoodlebrink
Years of Experience
20
Yeah I whip up a shampoo for special care fabrics, sponge on, horse hairbrush it in. Sometimes I'll even extract with vac only on heavier soiled areas, and then use towels afterwards.
Shampoo heavily soiled rugs regularly as a prelude to washing. Lots of people use their encap shampoo as a prelude to extraction.
Vivers
Bill
For low moister cleaning fabrics we simply use the foam only to clean the difficult areas with a vac and possibly a light mist & vac
Steve Lawrence
We use Von Schrader dry foam method for most moisture sensitive, high-end fabrics. It's much easier and faster than the sponge/bucket method. However, the machines are expensive and require care and maintenance. We have 6 units to swap out parts, etc. to keep 2 running. It's a great method to minimize moisture and do a thorough job fast. Results are almost always spectacular if fabrics aren't too soiled or stained.
juniorc82
Jon Coret
what about running shampoo through a cimex or gracity feed on a 175?
Mardie
Mardie VanBree
I dry foam all rugs and upholstery using machines for application agitation and extraction. Could not imagine doing it by hand with a horse hair brush LOL.
The dry foam i use is not a soap it is a detergent.Their is a big difference between soap and detergent. (dictionary) Oh and when you see soap written on a carpet or upholstery cleaning jug it is more than likley a name they just put on the jug because it sounds better for marketing purposes.
no a dry foam. I own a cimex and am encap all the time. I meant like using a dry foam on a area rug or an oriental
Never.
I've seen those soap boxes but I'd like to think we are more professional than that.
Mardie
Mardie VanBree
Like encap shampoo? We do that nearly everyday.
I encap regular also but more often than not i finish the job with dry foam extraction .
You Richard would be shocked at the improvment dry foam extraction makes after encaping any job. Kinda like putting the icing on the cake.
Mardie
Mardie VanBree
Sorry delete "think" and insert "know".
Making such a rediculous statement and stating that this is something you know endorces the fact that so many people like yourself live in their own self imposed fantacy reality.
Making such a rediculous statement and stating that this is something you know endorces the fact that so many people like yourself live in their own fantacy reality.
Yea duhh it's called the internet.
Mardie
Mardie VanBree
Richard it is stuck in the mud thinkers like you that make me so successesfull.:rockon:
Glad I can help.
I'd like to say the same to you but we have no foamers here, haven't for decades. :shifty:
Steve Lawrence
I started out with that VS foamer. BTW, that one in the pic is spitting wet foam--something wrong in the detergent mix or equipment as the foam should be fluffy and airy.
I struggled with that system for a couple years before I discovered Deep Steam Extraction portables. They were a struggle, too, because they were soooo heavy but at least we could get dirty carpet clean unlike the miserable results we would get on dirty carpets with the VS. Mardie, you should get around more--there are much better processes out there. For the same price you could have a kick butt OP System.
Mardie
Mardie VanBree
Steve i know that very few people have been able to make this system work for them and i believe that it is due to their lack of understanding on how to use and maintain the system.This is not a filler up and go system. I know that when this system is managed properly that i can achieve amazing long lasting results.I dual process with the cimex on a lot of nasties which realy speeds things up.I use the foam as a carrier for extraction (not the brute part of the cleaning proccess).The VS foam detergent also gives the best finishing touch that any cc could ask for.Properly applied presprays and treatments along with the agitation do the work (not the foam).I am also exploring Steve Smiths product line to increase my efficency.I use some Bridge Point products(love hydrocide extreme and their black light lantern)and Pro Chem products.
I do a tremendous amaount of restorative carpet cleaning. I also have several clients that use me for just the bad stuff.They give the cheap easy to do stuff to the HWE guys.
Every time i takeover a commercial job that has been HWE my return tank comes up like sludge that i dig out from the bottom of the carpet.
I can easily and perfectly clean the geasiest restarount carpet with no problems at all.
I am very open minded and am always looking for ways to improve.
Richard, just give up!
Mardie, does not seem to get the concept that any residue(soap, detergent, foam - whatever you wanna call it) left on/in the carpet/upholstery will attract dirt.
Tony Neville
Tony Neville
You are NOT supposed to drink the detergent!
Of course if you do that may improve the results on the carpet!
Tony
Mardie
Mardie VanBree
And you are saying this to Richard the king of encaping.:icon_rolleyes:
Wow now I'm a king? King Richard ....that sounds vaguely familiar. ;)
One of you fookers owes me a crown and round-ish table. :winky:
Encapping commercial carpet is fantastic, everyone does it.
Encapping/shampoo my kids bedroom carpet, different story.
