KevinL
- Jan 5, 2007
- 2,928
- Name
- Kevin Leach
Hey mechanical guys, I've got a roots 56 in a white magic cds. It starts to bog down after a couple of hours running and I think it was low on oil as it's hard to read where it's suppose to be. I changed the oil for the first time in 3 years and put a new tension pulley bearing on but still not running right although it spins freely by hand. Do you think a bearing is bad and is that something I could change myself or should I take it to jondon 160 miles away? I could only change the one bearing on the outside, no way could I get to the other side and if it had to be replaced I couldn't do that because of all the rusty connections. I have a back-up I'm using so should I just take it to the pros?? Thanks.
