- Oct 6, 2006
- 116,890
Zee had this to say in a auction and I thought it was worthy of a conversation
What exactly ion the formula is creating the issue?
Do other powders do the same?
A while back some of us were having issues with Soap Free causing corrosion on brass parts but this sounds like a different issue..
Masterblend Rage is good.
BUT.
If you have a fuel fired heater that operates with a flow switch- DON'T use it. The white powdery build up in your hoses and heater WILL get your flow switch stuck and get your burner burn full blast even when you have no water running thru the system.
It is dangerous.
I tested it a bunch of times where I normally run acidic rinses (Endzone, Last step) and my system is clean and never a problem anymore with the flowswitch. Now if occasionally I mix in the powder emulsifier (Rage) and meter it thru instead of the acidic liquid rinses, it is 100% of the times will create a flow switch stuck situation.
