GCCLee
- Jan 29, 2012
- 5,113
- Name
- C. Lee
I hit that with 700 PSI all the time. No biggie.
Golden Boy
Fred H had a really good question, How about agitation?
Common sence tells me that the longer fiber is likely to get hung up in a rake. 2 jet wand at 700psi ? GOOD GAWD!! we will keep it between 250-300, k
There is one walk in closet that has a nasty traffic lane up the middle of it. I was going to rotovac it with the glided head.
Steve,
Only thing I have on hand is H2O based : FourGuard
You should clean it like you clean any other carpets. Agitation is great if its called for it, raking the modern shag is not a problem either. Like all the other carpets it will wear out and for heavy traffic areas it will be more obvious. Just talk to them about what you are going to do and talk about how and why carpets wear. Been cleaning that type of carpet for 15 years almost and never had an issue.. its all about confidence and if you don't have it the customer will smell that out and question EVERYTHING you do.
Lee is right, low pressure. Be careful with agitation, especially rotary agitation. The fibers can lose twist, blossom, bloom or whatever description you like. Soft brush may help work in your prespray. No need for grooming following the cleaning.
you have never cleaned frieze carpet??? thats probably about the most common carpet nowadays. if its a polyester frieze I highly recommend using a CRB machine or 175. I have carpet similar to that in my own house. its a poly frieze, builder put it in. just cleaned it with flex w/citrasolve. it came out excellent and seems to not be resoiling as fast. although its too soon to tell on that.
Wow do any of you fooken clowns clean carpet? California berber is the only style of that carpet to watch out for. You can blast the shit out that stuff and pre scrub it also. I clean the stuff at least three times a week plus its in my home. Pre vac if u want to get your top 25 ranking. Pre spray with cobbs powermax. Agitate with you POS Hruby. Rinse with a Twand and Jeff Lydons perfectly fitted glide. Rinse with clean water. A 56 Blower helps. Dry stroke needed if you are a ex-Vortec owner currently running a 33 Blower. Have a box of tissues close by if you and your helper/boyfriend just broke up.
Golden Boy
It's starting to feel like TMF here with all the dum questions.
Really?
