Calling all Magic Wanders
S
Soxpac
I'm making an order to MW and I'm using Grease Eater but need a detergent and an upholstery prespray. Would Magic Potion be alright or should I use trashed neutral? Green is a bit pricey but if I had to, I would.
Sent from my LG-LS840 using Tapatalk 2
Trashed Green is an amazing uph prespray
Magic Potion is most likely STPP so make sure it has corrosion inhibitors before you subject your plumbing to it.
S
Soxpac
(((((It is also loaded with natural water softeners to improve cleaning performance & to keep your machines clean. Formulated by Chemists, and field tested by veteran carpet cleaners. This 100% biodegradable concentrate contains descalers, has water softeners (conditioners))))
Thats all it says. I refuse to buy "Porty Power" lol so I hope MW has something.
S
Soxpac
You think the red trashed would be better than MP for detergent and upholstery?
MP for a rinse Green Trashed for uph and pre spray.
I dont use enough of their other stuff to know more than that.
Reactions: Soxpac
joeynbgky
Joey
I use trashed green its very concentrated. Call dee dee and ask her. She will tell u.
Sent from my SGH-T999 using Tapatalk 2
Reactions: Soxpac
R
renegade_cowboy
I use Trashed Green and usually make about $7,000-$8,000 per gallon using it on uph and areas rugs as well. SO not so pricey and its a very good product.
Reactions: Soxpac
S
Soxpac
Do you use it as your prespray as well? If so do you use it on res and com?
R
renegade_cowboy
I use it on both as a prespray.. haven't had any issues with using it.
S
Soxpac
I was considering getting some more GE but getting a case of green as well. Think I will. I need to buy as many versatile products as I can because I'm still new and need to maximize profits as much as I can in order to stock up in other areas. Oxy Blaster seems good too.
R
renegade_cowboy
Grease Eater is the bomb.. if you have never used Trashed Green, you get 30% off.. To be honest my chemical cost is around 1%.. so there is many other ways to maximize your profits.. just get the best of the best for preyspray and it will take care of you.
S
Soxpac
Right. I'm starting over with chemicals as I ordered my first batch in bulk and I don't like the stuff. Ive had to scrub when normally you shouldn't have to because of it. I want to have a limited amount of chemicals on the van and with MW that seems possible.
R
renegade_cowboy
I also like Trashed Green because its certified green, which is good for marketing. You use Fels?
S
Soxpac
I just bought some, haven't used it yet
