Help my parts fell out of my Suttner Pressure Regulator
200 psi?
what portable did that fall off of?
a bit more information is needed for us to help out.
what can't you figure out?
check to see if part 3/4 (same as 7/8) remained in the assembly..its still plumbed inline right..you probably aren't actually missing them
edit: and you might want to print that schematic in case that link disappears too
edit 2: There is also the possibility that 7/8 isn't used in an updated version. I say that because the link on suttner that is broken is in a subdirectory "New_050609"...which I assume is a date.
The schematic I linked to is dated 05
my money is on 3/4 still being in the assembly though
Reactions: falcans
R
renegade_cowboy
gotta go back to the truck now to reinstall it be back soon thanks again for all the help!
Hope that helped you out, sorry I forgot to respond to you text. See you shouldn't always believe what you hear about MB.. some of the best minds in the industry hang here, along with some of the most experienced.
Good place to hang..
Reactions: falcans
falcans
Thanks again fred your a life saver!! there is already o-rings on the piston so i should be fine
Ya it does fred seems very knowledgeable thanks again brent!
Here is a link directly from my website
A month or so after getting my TM, I had one vibrate off during a job, talk about scaring the doop out of ya. Water squirting all over!
Pieces all over the ground...
falcans
ouch that would be very embarrassing how the job turned out well?
I will be testing the water today on it if not gotta fix it asap so busy this week just got this gas truckmount and i feel im over whelmed with work now lol its so dam true versus electric and gas
