18-24 flow
Dallas, Texas USA
Is there a slide in that will handle the 24 t wand that will be at the fest, I would like another unit.
Ron;
You need to do a bucket test to determine how many gallons of flow per min. you are actually putting down on the carpet.
Slide-ins can deliver the GPM needed,
when the pump is driven correctly.
Larry
Arizona
go over to the Sapphire barn and check out the .454..570..or the 870.....I spent a lot of time playing with them at the last MF....Pretty sure they will do everything you want them to do and more.........
bring a five gallon bucket, YOUR wand and a pen and paper to take notes on how every unit there handled the Lippy Challenge.
you or I can post the results the following week.
Reactions: GCCLee
juniorc82
Jefferson City missouri
Jon Coret
Wow is the juice realy worth the squeez running flow like that? I would imagine you would need to run an apo on flow like that as a good size jub would fill your waste tank pretty quick
Albuquerque
Ron lippold
There are not many jobs that we don't have to drain the tank, pretty much anything over a couple of rooms 140 gallons down the drain.
