BLewis
- Jun 17, 2008
- 1,693
- Name
- Billy Lewis
Jim, Mikey, Whoever,
I know primarily you use this for resi, and I've heard most love it for nasties. Since I am 90-95% happy with results when just wanding, we do have this one large property management company that we service that mostly has middle end homes but also have occassional semi-nasties, my question is can you employ the Hoss just to clean traffic areas (which is where I sometimes lack "excellent" results) or if you use the Hoss in any part of a room like the traffic areas is it best to use it in all of that room?
Or once you start using it do you find yourself going to it more than the wand? Seems to me it would be most beneficial when servicing a resi that has let their carpets go longer between cleanings than they should or a first time clean that hasn't been cleaned in 3-5 years.
I know I'm about 1-2 years behind the curve but that is intentional since I learned several years ago (2006 Vortex) not to purchase new toys until the manufacturing bugs had been worked out. Seems the Hoss has gone through this process now and it's time to purchase one.
I tested one in my nasty chinese restaurant (they clean every 4-6 months) it did a great job however it took us 1.5 hours longer than 175ing the troubled areas and wanding. However the water flow wasn't correct and I didn't take the time to fix it (new to me) on the job so I can't completely know if it was 1.5 hours slower until I tried it with correct flow, I guesstimate that it would only add about .5 hours with the flow set correctly. It also did not have the upgrade to all the long water flow bars.
