HOSS Video
Todd
I picked up one of the HOSS machines on the killer deal here at Mikeysboard. That was just to good to pass on. Here is a short video of it cleaning a greasy berber. I don't think I have the right flow restrictor in to balance my machine yet but so far so good.
She definitely has more torque then the 360 and takes more energy to run. iT is a real beast.
http://youtu.be/LR8Qx5gszbU
What truckmount are you hooked up to?
Up your flow so you can speed up the cleaning pass.
Did you make sure the handle was straight?
Todd
It's just a Blazer GT 18hp 36 blower running 300 psi 100' . Yup handle was straight lol
I think I have the 48 size restrictor in .
Fiddle around with your flow but don't go hog wild with that small blower
Todd
Maybe I should turn it up to 350 psi ? Or would it be better to go with the next size up restrictor ? I think it's actually the 47 restrictor. SS sent me 6 sizes. I'm very happy with the build quality of this machine. It is top notch.
Studebaker
Studebaker
You should be able to get closer to that transition. With the right to left pass you can lift the head to clean over that tile, if your careful.
Goldenboy
Mike Waldron
Is that a revamped Trinity? Good idea to use the tool to Flush the carpet out. Can you believe there are cleaners that would just swirl that dirt around. Sick and Disgusting! ToddI I bet your garage is a Craigslist Haven.
Golden Boy
Todd
Golden Boy
TOO Funny Waldo. You are right my garage does look like a Craigslist Haven. :hopeless:
That hoss Is way quieter than ours, ours makes a couple of different noises that have been addressed with these newer units. Looks and sounds solid.
The new wheel and axle system does make a BIG difference in the sound.Big.
