hydramaster cross fire 4.2
falcans
Hello i have a hydramaster cross fire 4.2 my heat exchanger has went and i have a north diesel burner that i had sitting around so i'm looking at cutting off the heat exchanger off and rerouting everything anyone have any suggestions for me?
J
juniorc82
get a new flow switch for the diesal so it will light the burner on lower pressures
Goomer
Frank Mendo
Think about venting that burner directly out of the van (roof?) somehow if you can as it puts out a ridiculous amount of smelly exhaust heat.
Flow switch Suttner ST-5 or ST-6 for lower flow as Junior stated.
falcans
Thanks im thinking of venting but worried about leaking from outside to inside its a all aluminum box......
the flow switch is fine i have used low psi and worked fine should be fine now gotta figure this out :D and gonna do the exhaust a member here pmed me sense he has done his so i hope i can get this resolved asap got a job wednesday and a huge tile and grout job next sunday!
