Propane tank
Charlie Lyman
Meridian, ID
Charlie Lyman
For those of you running a Little giant heater, What size propane tank do you have under the van and how long do you go between fill ups (hours of use)?
Shane T
Waukesha, WI
Shane Tiegs
I have the small one(10" diameter) . I use my #3 LG as a post heater and get about 30hrs truckmount running time. I would suggest getting the largest one that will fit under the van. I think I could have fit the 12" one under my GM extended van.
We always used 100lb belly tank, twice a week refills depending on hours run.
You can get smaller but then it just adds to your refueling trips.
KevinD
Binghamton,New York
Kevin Dumas
Under my older truck I had a 18 gallon tank until the Northeast salt took it's toll on it.
The best I could find to replace it with was a 14 gallon tank from Manchester.
Anybody in need of one in Upstate NY, let me know. I still have it in storage from when
I pulled it off the van and went heat exchanger.
joeynbgky
Bowling Green
Joey
11 gallon tank once or twice a week fill up with van running full force. If u have a 100 gallon tank and fill it up twice a week. Somethings wrong. No way u can be using that much propane
Samsung galaxy S IV beta tester
yes, lbs . I don't know it's been several decades since we used propane. I asked the only tech that was here then and that's what he told me.
joeynbgky
Bowling Green
Joey
Sorry we go by gallons my tanks an 11 gallon but holds around 7. Thats how we are charges so I dunno about pounds
N GA
BradFenstermaker
My Tank is stamped 9.9 gals. Usually go 14 hrs of run time. If only residential I fill 1 a wk. Mix with commercial 2 times
Mike Draper
one thing to consider in cold weather. When you have a smaller tank "10 gallons" the propane evaporation is not the same as larger tanks. This makes a big difference in the winter when it comes to heating your water as it does not heat as well.
