Powermaxx vs Prekleen
We sprayed facing the dresser to our right with prekleen to the left where you can see the bigger chocolate stain powermax. The dividing line is between the drawers in the dresser.
http://youtu.be/Ao5EsgWokBU
The photos were a picture of the 2 different products used and I just added the video sorry! and the prekleen side did look a little lighter.
For the money Powermaxx works great. These 2 product are similar, but the PM and the SP is nice, did an olefin bur bur and I've done it with extreme clean and enzall my customer was like if looked better then ever.
Dallas, Texas USA
Sam;
Thanks for taking the video.
For stains like chocolate, the oxidizer will continue to work after the initial extraction.
It would be best to photograph about 30 min. after extraction.
That is probably why the Olefin berber looked so good.
Larry
P.S. I would shorten those jet extenders, to give more even cleaning across the wand width.
Prekleen contains NO oxidizer or D'imo and is a lower pH than Powermax so why would you say they are similar?
A more interesting comparison would have been with Enzall and PM
Dallas, Texas USA
Marty;
I appreciate anyone who takes the time to do side-by-side testing . . .
One question for you:
Did the chocolate stains on the left look much darker,
than those on the right ?
Larry
Dallas, Texas USA
Nope . . .
It is next Saturday in Wichita Falls.
We are still assembling testing and cleaning equipment,
for the ETM vs. Gas TM main event.
We will be using the 12" x 2" Bentley for the vacuum test comparisons.
(Best 12" High Airflow Wand available)
Each 4' X 8' panel will be sprayed with 2 gallons of water @ the same pressure before the vac testing begins.
Nick has a container to measure actual water recovered from each 4' X 8' panel of plush carpet.
Larry
while the airflow design on the Bentley is great ("best" has only been stated by YOU, and not NASA so I'd be careful with that endorsement) the manifold design and placement makes the wand unusable IMO.
So how about using your CMP wand for the tests. It's far more popular and obtainable.
It does have de lemonine
Citrus terpenes read your label it doesn't have oxidizers and is a lower ph
Bad doggy! This time I sprayed 1/2 powermax and some KOP then spray enzall and KOP. Rinsed with all fiber rinse and cobbs brightner.
put down the bong and e edit your photos in Paint to show where the dividing line is and what side of the room each product was used on and wtf is KOP?
Ne
So if I understand you added some oxidizer to your all fab rinse thru your TM?
kill odor plus and I believe its 40 volume peroxide its a liquid I add a cup into the rinse.
Goomer
Bronx, New York
Frank Mendo
Based on the size of those spots I would think it traveled well into the padding...............I wonder if it gunna stank tomorrow????
San Francisco, CA
Just maybe the looks (in both) difference has more to do with where the light is coming from, light reflection and proximity to light source?
Nah!
According to Sam's previous posts, he gets everything out. Every single one.
I dont know if I would go that far, but I can replace pad and seal the sub floor if needed.
nasty little chihuahua
