SS Uph Tool Flow
Johnny
Johnny
Is the flow supposed to be consistent across the tool? The holes on each end and to the right and the left of the center hole appear to emit much less than the others.
Can't really tell if streaking will result cuz I haven't used it much, and when I do I overlap a lot to be safe.
I have uph to clean Monday and wonder whether I should take another tool.
Doug Cox
Doug Cox
Take it apart and clean all the crap out of the inside. When mine is full, the flow gets erratic.
Reactions: Johnny
Johnny
Johnny
Thanks, Doug. I'll check it out, but I don't think I've used it enough to fuzz it up.
Johnny
Johnny
Took it apart, (much easier than the DriMaster). Solution channel perfectly clean. Very little fuzz in vacuum chamber.
Mine streaks also at times, it's not evenly wetting the fabric. I just go over the area again.
Cleaning mine has helped this.
Studebaker
Studebaker
Under vacuum especially a larger truck mount it can appear that there is gaps in the flow. Usually it is because of so much air flow, the solution is being pulled in faster. When you have it on the fabric it evens out across the head.
Under vac with solution, place a clear piece of plastic over the head and you will see the coverage is 100%
Johnny
Johnny
Thanks. Good to know it's working right.
While I think that the Sapphire Uph. tool is a good tool . . .
my customers have complained to Sapphire about the center of the tool not spraying water evenly.
This trait blemishes this otherwise top cleaning tool.
Larry
Something new Larry or an original problem? Just something they visually noticed or is it causing a difference in cleaning?
I've not seen that while using it or heard that from my tech's using it. We have (4) of them two original and two I bought last year.
There is a flow control also, you have to adjust that some fabrics need more flow
some less.
Also P/T the fabric and give it a scrub it will clean easier than just steaming it.
yep... That's what it does.
Steve Lawrence
Man, I'd always heard such great things about this expensive tool.
Let me know when they get the bugs worked out.
Until then, PMF internal jet for me.
KevinD
Kevin Dumas
I was disappointed with the spray bar setup from day 1.
Needs a major overhaul, (holes,spacing and vac slot design and position) IMO.
I went back to my glided Prochem tool.
it's still the better tool in every way except ergos
I'll keep our SS tool for that reason, but will use the PMF internal jet 96.47% of the time ...becuzzz, it's a better cleaning tool
Steve Lawrence
The better tool in every way but you use it less than 4% of the time?
Bill Bruders
Bill Bruders
Larry
Geez Larry since your an expert on modifying every manufacturers product I shocked you don't have a solution that Addresses this "issue" lol Could it be that the answer is as simple as explaining how you adjust the pressure to balance to flow? Or could it be that the tool is designed to flush through the fibers creating superior cleaning and faster drying rather than say an internal
Jet tool which still puts down a lot if water but doesn't have the overspray of a cheaper external jet.
Maybe if you contacted Sapphire and became an expert on our products (like you seem to be on every Mytee product) your customers would get the info they need to use this best selling tool from you when they buy it instead of having to search for answers elsewhere. :-)
Sooo Bill, would you mind explaining?
Sorry Bill.
Had both.
PMF better.
Sold SS.
On the other hand, many here love your tool. Just one BDCC experience for whatever its worth.
Questions?
Bill Bruders
Bill Bruders
Cooper PM Studebaker I'm certain he will be able to help you put.
Ofer well sorry to hear that I'll assume you gave someone a heck of a deal on that SS tool :-)
Johnny
Johnny
I also have owned a PMF for many years. It's good for carpet detail work, but leaves uph much wetter, even with extra dry strokes, than my SS or DriMaster. You can scrub better with a PMF, but I pre-scrub with a brush or orbital hand buffer. I just want a ONE-PASS RINSING TOOL that will leave the uph reasonably dry. Shouldn't have to overlap or make multiple wet or dry strokes in most situations.
