- Oct 6, 2006
- 117,272
Rug Doctors are all the rage with them so I gave them this lecture...
How'd I do?
- Get a Shark Navigator vacuum or it's equivalent (Dyson or the latest Hoover Dirt cup design) and vacuum all the carpet until no more soil comes up. Pay special attention to entry areas, in front of the TV and where the dog sleeps, work it from at least 3 directions. Dry soil is a hundred times easier to get out than mud.
- Pick up some "20 volume/9%" Hydrogen Peroxide from Sally's beauty Supply (liquid, no cream) in a quart bottle and thread a trigger spray on it. As soon as you are done vacuuming liberally spray all organic (urine, coffee, soda fruit etc) spots/stains with the H202(Undiluted). Do not use this on wool or any other natural fiber rug or carpet or furniture.
- Get a pump up "Hudson" type sprayer and fill it with SOFT water as hot as you can get it. Turn your water heater up if need be. Leave room to add 2 ounces of premium carpet cleaner "Pre spray". Your local Janitorial store or carpet cleaning supply store will sell it to you if you walk in with a your wife beater on. Make sure to park your Trans Am out front so the guy behind the counter can see it removing all doubt that you are not a certified professional CC'r. Prochem, Chemspec, Pro's Choice are all easy to find at supply shops. Or you can buy the Zep Traffic Lane Cleaner from Home Depot.
- With your Hot Hudson mix practice spraying your driveway so you can get a feel for how much liquid it will take to get your carpet fibers wet from top to bottom without getting the backing soaked. Work about 100 to 150 square feet at a time. Anymore and the pre spray will work it's way into the pad and take forever and a day to dry. It will get moldy and reEk for days on end so take it slow and easy.. next take a clean push broom and scrub the carpet in a few directions. This will help break the soil loose and make rinsing easier.
- Now fill up your POS Rug Doctor with hot SOFT (if possible) water and half a cup of white vinegar to every gallon ran through the machine to help rinse out the prespray and to neutralize the carpet. Apply the water/vinegar solution only on the backstroke only. Due to lack of real heat, water pressure and vacuum like the Pro's have (Me) you may to need to pre spray, agitate and rinse real bad areas more than once. DO NOT USE MORE THAN 4 ounces per gallon. More is not better.
- Once you have the area looking good, use the Rug Doctor to dry stroke until you no longer are recovering water. Fiber content and density, amount of pre spray and rinse used will dictate how much time you'll need to dry stroke the carpet. Keep in mind that you are removing soil as well as water so don't skimp here.
- When you are content with that 100 square feet set as many fans on the carpet as possible. Consider renting a Snail /Water Damage fan if you'll be cleaning in the winter months. turning the heat on and closing the windows will only slow down the drying process, fresh airflow is what it's all about. If you have a built in house fan or want to run the AC at full blast that will work too.
- Wood or non stainless steel furniture legs placed back on damp carpet will need a plastic barrier under the legs so rust or wood stain does not ruin your fine flooring.
- You won't be able to clean staircases with that POS unless it comes with a hand tool. Rug Doctors use to come with a real wand and hoses but idiots kept breaking them by slamming them in the trunk so RD came up with this lame all encompassing Box design. Sorry.
- next summer after you sell the POS at your yard sale, don't forget to tip the pro you hired to replace it.
How'd I do?
