Stripper
Lyman
Johnstown new york
Lyman
I have been using unitex sledgehammer, just wondering if there is any better stripper out there. This stuff works great but foams a little. A real pain to rinse by mops out at the end of the day.
Fort Worth , Texas
What is better for you?
Do you want it to instantly emulsify?
Do you want it to stay wet longer?
Do you want it to smell better?
Do you want it to be more concentrate?
I like Johnson's diversey faststrip because it works fast but it also will dry and reharden very quickly.
I like Johnson's diverseys bravo when we are doing larger areas and apply stripper to larger areas at a time without worrying that it will dry so quickly.
My guys like spartan shine line emulsifier because of the sweeter odor.
Mardie
London Ontario,Canada
Mardie VanBree
Although I am very new at doing this type of work I would suggest using a wet vac to remove the initial load from the floor so your mops don't get all bunged up.
Shane Deubell
We like betco or johnson products, the local distributor carries betco so that is what we use.
