Juice Report
G
GCCLee
What would you have used?
This was 1 slow and steady pass w an AW29 at 190 degrees, a few extra squirts here and there though. Still under max recommended dosage.
Fingers are white but my hair looks much better now : )
A foam bat to hit the client over the head with, while yelling - who does this, who does this and so on...
That's pretty bad.
Reactions: GCCLee
Prochem Powerburst @ 3 heaping scoops pr gal (nuke and a half strength*) mixed in hot water (120-140 degrees)
applied at 150 sf pr RTU gal
* nuke and a half strength will work better with most all chems.
Example, if max recommended is 6oz pr gal, going 9 oz pr gal will increase efficacy
However, there does come a point of diminishing returns and you're simply wasting chem by adding more .
..meaning , going 12 or 14 oz pr gal in the above max and a half example probably won't do much if any better **
**That can also be somewhat contingent of the juice too
some tout a ridiculously low dilution rate to make them appear to be super economical , when in reality the dilution rate they suggest is only good for "clean" carpets and need to be doubled right from jump street to clean anything soiled
On the flip side of that are Cobby's recommended dilution rates ..they're already max 'n 1/2 and more than is needed in all but salvage rags
Reactions: GCCLee
G
GCCLee
Reloading manuals give a min and max charge : )
Theres a sweet spot in there!
'cept you can "double charge" juices without blowing up your sprayer....:biggrin:
speaking of ka-booms...
One of my buds blew up his pistol today :eekk:
running a timed course , putting doubles on each target, had a squib (which doesn't cycle the slide) pulls the trigger "click"
so he instantly/instinctively does the tap-rack MALF clearing procedure and presses the trigger ....*KA-BOOM*
Bulged the barrel and locked up his $2800 Ed Brown custom:redface:
G
GCCLee
Not an EB kaboom : (
That sucks!
Glad he didn't get hurt. Them squibs can get ya.
