Rain blew a fuse on my 2010 Butler panel--thanks Butler!
Steve Lawrence
During a heavy rain our side door was open a bit too wide while we were in a job and the rain must have gotten our electric charging cord socket (for a Multi Sprayer) wet. It blew the fuse and the light on the switch was out which was nice because it showed us there was a problem. The nice covered fuse box under the passenger seat easily opens and has a nice diagram for all the fuses and modules. It even has spare fuses and a fuse puller should you blow one. Easy to find blown fuse and spare made it an easy fix.
Thanks to the Butler Corporation for making the fix so easy.
They put those hose ports on their doors for a reason, dumbass.
Marty U R A dumbass! The Butler is an awesome setup with no need for a hole in the door.
Steve try putting a Sticky Tab over the socket, if that doesn't work look for some type of plug at an ACE hardware.
Reactions: Steve Lawrence
That dude is in love with that port.:oldrolleyes:
You can't or won't want to wind your hose up or off the reel, pulling it though that opening.
Smarty it's just not that great of an idea, more fluff than function.
Have any of you Butlerites ever found a reason to use that socket?
Steve Lawrence
Our 2.5" hose is loose on the reel and it's not difficult at all to pull all the hose off and then string the loose end back through the hole and attach to the 2.5" barb on the waste tank. We do that on very cold days. We even have 2 holes on this truck so the pressure hose and vac hose each have their own holes.
