Depressing!
Mike Draper
Sometimes there is nothing you can do to shitty carpet to get it clean. They Paid for dirt cheap carpet that's usually the end result.
Reactions: GCCLee
OneBlueSummer
Growling Sheep
Sup dude’s this is my first post! Been a lurker for a while and found a thread I think I might be able to help with! :eekk:
Why not try and add some light reflective stuff back to the carpet?
Looks like you raked it after you RE d it ..
You will find if you run a post vacuum in the same stoke lengths of a wand you will have made the appearance twice as better.
To further ice the cake, mix up some heavy encap in a separate jug and inline sprayer all the “traffic” areas. Then either hit it with a bonnet and a 175 or just run a post vac. Encap will add a gleam effect to any carpet and really make stuff POP.
As for the dude’s talking about pre spray.. this plastic carpet reacts best with solvent’s such as ammonia …
poly/olie cut piles beg for rotary scrub before the extract .
that's why your pixie dust after scrub improves it
in lue of roto scrub and extract, you need mega heat..heat that 93.74% of TM's can't produce.
I'm talking 280+ ATM...250 ATW
AMD sledgehammer chems to nuke it
It's been a few years since we've been beat by one of these. The one pictured could be successfully cleaned by several guys here.
Don't give up so easily, you will be stoked when you beat it.
