Thoughts on using this for a recovery tank
Royal Man
Dave Yoakum
Looks like there is no reiforcement to keep it from colapsing. You might as well use a 50 gallon barrel.
Reactions: Art Kelley
Shane T
Shane Tiegs
The welding needed to make it work will damage the epoxy. That will cause premature rust and eventual failure.
I'm Rick James
I think this tank can survive our blowers suction, its designed for high pressure..
Is there any way to reapply the epoxy after it has been compromised?
I already have two extra waste tanks but want a cylindrical one for a new TM i am in the process of building. I don't mind modifying the tank to make it work for a recovery tank.
As long as you have an air brake for relief I wouldn't think it would hurt it.
See if Brevik will sell you one of his, aren't his stainless steel? The difficutly with reinventing the wheel is the time and money invested in something that is already be produced.
I'm Rick James
I think Brevik is the man when it comes to welding and I already tried to buy one.. but he won't sell them separately.
I see, Terry can be a real dik sometimes. :p Seriously I can see that he doesn't want to tear apart his system for one sale and then be tied to it for it's life.
Aerotech or is that too big of a waste tank?
Askal
Al
A 55 gallon metal drum will not work. Don't ask me how I know but it makes a very loud boom when it fails. Sounds like a few sticks of dynamite.
Reactions: Steve Lawrence
I'm Rick James
I got off the phone with them.. they said the tank can withstand the pressure but they were unsure of the epoxy lining and our chemicals.
What are your thoughts on the epoxy lining?
I'm Rick James
I think the lining would be fine, it's your cut points that will be the problem over time. Since there is no Epoxy in the cut points, corrosion and rust will likely start there.
What about Mytee's molded recovery tank? I think you'd b money ahead and not have to weld or cut as well as no worry about corrosion.
http://www.mytee.com/products/t-80r-the-tank-recovery/#.UkWw-z9MuSo
I thought about that but after shipping and tax its going to be over $800.. Plus i believe the cylindrical design of the tank will provide better air flow.
What about having the epoxy reapplied to damaged areas from the welding?
I would think it would be fine provided you prep the unfinished area well, so it will bond. Even if it failed I would think you'd get years out of it before it did.
I'd still weigh all the costs associated with getting it up and going vs the Mytee.
Shipping, welding, gaskets, epoxy, time, all have a cost. It would be a shame to make nearly the investment in your own tank and it not work for you. ???
Shane T
Shane Tiegs
You could cut the new holes with a hole saw and then use a pvc bulkhead fitting instead of welding the fittings in.
