Oct 25, 2013 #1 Mikey P Administrator Joined Oct 6, 2006 Messages 116,648 Location The High Chapperal
Oct 25, 2013 #2 kingjoelking Supportive Member Joined Nov 7, 2011 Messages 521 I dont understand. Why did you have to throw those other 3 pieces in on the bottom hose. if it allready necks down from 2.5 to 2?
Oct 25, 2013 #3 Mikey P Administrator Joined Oct 6, 2006 Messages 116,648 Location The High Chapperal You can't put a 2 to 2.5 cuff on every 2" hose, right? Since we dual wand most jobs we need to be able to run all sorts of crazy hose set ups and options.
Oct 25, 2013 #4 kingjoelking Supportive Member Joined Nov 7, 2011 Messages 521 Yeah that makes. Since, As a never dual wander I forget that other people work like that.
Oct 25, 2013 #5 Becker Member Joined Oct 8, 2006 Messages 7,359 Location Snohomish, WA Name Becker I like the lower set up..
Oct 25, 2013 #6 Cleantechsk Member Joined Nov 3, 2010 Messages 649 Location western Canada Name Dustin bottom for sure! except extend the centre hose length to 2 or 3' easier to go around corners,etc
Oct 25, 2013 #7 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Location Benton KY USA Name Lee Stockwell Cleantechsk said: bottom for sure! except extend the centre hose length to 2 or 3' easier to go around corners,etc Click to expand... and longer less likely to be lost or left behind.
Oct 25, 2013 #8 K KevinD Member Joined Nov 23, 2006 Messages 2,497 Location Binghamton,New York Name Kevin Dumas I just use the thin wall barbed aluminum 2 1/2" X 2" connector (hose to hose) and forget about all that crap.
