- Oct 7, 2006
- 10,877
- Name
- Jim Martin
2 jobs today.....last one was pretty good size....
got to the first one..set everything up and got going and the shaft snapped again on the Hoss.....
and as always...I am way across town and cant run to the house to get my other one.....
Not the re-called aluminum one..but the new stainless one.....rigged the thing up with a bungee cord to get me threw the job.........it held the shaft in place and kept the height adjuster from falling off.........
got done and swung into the hardware store and bought a stainless shaft and had them cut it to size...and grabbed 4.......1/2 inch lock collars.....and put it together in there parking lot.......
got to the 2nd job and it held together and worked great..........
the shaft snapped the exact same place as the aluminum one did......it is where the grove is cut into the metal for the "C" clip.......once that grove was cut into it ..it weakened it at that point......
suggestion....when these shafts are made.....use lock collars like in the picture above to hold the height adjuster in place.........and stop cutting into the shaft........all your doing is stabilizing it from floating around......
I will order a new shaft on Monday....and when I replace it I will put the things that I bought in the truck for back up in case it happens again....I think I will buy another set up and put in the other truck as well.....
