New Prochem Titanium 4 jet wand
Looks like they may have brought the outside jets in a bit.
Hope so.
That Y at the bottom to the spray bars is what prochem uses on their ergonomic wands.
I had to replace my original ti Y and thats what I got looks dorky but works.
Mikey;
I like your choice of the 4-jet manifold.
Fortunately, the inside 95 degree jets look good.
Unfortunately, the outside 95 degree jets are too far apart.
Even Marty can see the problem with the outside jets.
Prochem R & D didn't do the testing that you claim manufacturers should do.
Let us know how quickly Prochem sends you a new manifold.
I can loan you a 4-jet Bentley manifold with the proper spacing.
Larry
First off Larry, the guy who continues to sell just about the worse wand ever made, Cobb, this design and project was directly between myself and PMF, other than letting me use the licensed head design, Prochem and their staff had ZERO to do with this.
Once I install the check valves and run it tomorrow I'll be back with my findings.
and if you re-read Marty's comments he is in favor of what he sees.
My Ti oversprays on both sides.
Yes, they all do. It has been a problem for years. Most guys don't "see" it, because they don't look, or don't want to know.
That is why I made the comment about Mike's wand and the outside jets. I hope they have moved them in a bit, so that the outside of the spray pattern lands within the confines of the wand slot.
how the hell is Waldo, Foster and the rest of the Mike wannabes going to afford , 360i's, HOSS's, Kirby vacs, AND new Ti wands?? :stir::stir:
Reactions: Bruce Humphrey
Mikey;
I can guarantee that the wand will Overspray MORE
than any Bentley we have sold.
It's OK, you only paid TWICE as much.
I hope they have moved them in a bit, so that the outside of the spray patter lands within the confines of the wand slot.
Marty NOT in favor of overspray !
Larry
We'll see..
unlike that POS Bentley, I can adjust the manifold hangers to do most anything.
I tried Cu's fix for overspray and it still is a joke.better but not worth having on the truck with so many better choices out there for the same price.
Can't be used under furniture (non swivel), can't be used on steps, cant be used by tall guys who want to push it waay out. worthless.
OMG EVEN MY FEELINGS ARE HURT!
I'm going to go lie down now...............and hope when I get up this nightmare is all over..............SNIFF!
Reactions: Willy P
Jimmy thinks every time he sees POS posted that they're talking about his Castex wand.
this wand will be a fine replacement for my old one..
Reactions: GCCLee
Let me see if I have this straight.
1. Plunk down $1300 for a $650 wand to work on.
2. Throw away the cheapie handle, and replace it with last year's metal handle from Mytee
3. Start hacking away at the metal sides,
so it can mount a $189 Teflon glide, that it should have come with to begin with.
(unusable without a Glide)
4. Redrill the manifold for the outer two jets, so it doesn't spray the baseboards
5. End up with inferior one-pass cleaning, compared to the 14" Bentley we tested side-by-side.
Greenie could trick it up for you, for under $1700
That is what a Vegan diet,
can do to your thought processes.
Larry
1. Plunk down $1300 for a $650 wand to work on. You have no idea what I paid for this wand and even with some mods done it's a life time investment unlike that pos glued together mess you promote that may last 3 years of light use.
2. Throw away the cheapie handle, and replace it with last year's metal handle from Mytee- which they rubber coated over the nuts that still turn .... idiots.
3. Start hacking away at the metal sides, -and you adding 34 bits of brass to the Bently to still not work even close to right is not "hacking?
(unusable without a Glide) It will include a Glide if we go through with this BETA project...- something Mytee KNOWS NOTHING ABOUT>>>TESTING IN THE FIELD. not for 2 minutes on your filthy show room floor.
4. Redrill the manifold for the outer two jets, so it doesn't spray the baseboards-Speculation.
5. End up with inferior one-pass cleaning, compared to the 14" Bentley we tested side-by-side.-Testing any tool or cleaning agent on the filthy soap saturated rag on your show room floor is nowhere to be testing anything but Giardia medications.
I've used both wands extensively in THE FIELD and the Mytee does not clean better in any way. It does draw well but the carpet is either soaked or streaked so it's really a mute point.
Stay tuned for real world in the field videos.
anything else Larry?
M
Mardie
I don't know shit about wands but dam Larry you just exposed Pro Chem as a terrible supplier of what they are so well known for. You have made several very good points. The not having a glide and not being glide install friendly thing really blows me away.
Jesus Mardie.... some time, well most of the time, you should just stfu up when it comes to anything but grinding in dirt with your 30 year old system.
Reactions: Jimmy L and GCCLee
T
tngvegas
I don't have very much money but i will borrow some and send it to mardie....so he can buy a clue. have you ever even used a tm? the ti wand is in a class by itself. You don't buy a ti wand throw it away three years later. if you take care of it it is a very good investment. Maybe all that foam you put in your customers carpets is creeping into the space between your ears.
go ride your trinity trike and make some money. when you really want to clean residential carpet we'll help you pick out a truckmount for you.
Reactions: GCCLee and Mikey P
M
Mardie
FU and what has this got to do with a TM vs anything else ? I am well aware of the status that this wand has. I am also aware that anyone using this wand uses a glide on it. So as far as I am concerned for that wand not to come with a glide and for it to be glide install not friendly is ridiculous. Kinda like buying a car that does not come with tires and no studs to mount them LOL. Sure wish I could sell a piece of pipe with a few spray nozzels on it for a thousand $ plus LOL I would bet Pro Chem could make you eat sh-t and like it.
Reactions: Art Kelley
Pretty much
But I honestly think Larry is always challenging me about Mytee stuff cause he knows I'll say what he is afraid to in hopes they get off their ass and start producing consistent quality and perform real RnD.
Long time Mytee vendors are fed up with the nonsense.
Anytime I can help Larry, I'm here for you. .
Send me an Escape or a TRex and we can debate those too.
