Russ T.
Customer spilled entire bottle of black nail polish just before I got here this morning. I have mostly Bridgepoint products and have a couple ideas of my own BUT.....what do you say? Thanks!
The Clean Machine
We use Proschoice products for that kind of spot and have had pretty good success. Pro solve gel works pretty good.
PROCEDURE:Step 1. Apply Pro Solve Gel to deposit.
Step 2. Agitate gently to work gel into deposit.
Step 3. Apply more Pro Solve Gel to cover deposit.
Step 4. Allow 5-minute dwell time.
Step 5. Agitate gently to fully dissolve and suspend deposit.
Step 6. Hot water extraction rinse.
Step 7. Thoroughly blot dry.
Step 8. If a visible stain still exists apply a solution of Stain Magic to stained fibers only.
Step 9. Cover with lightweight terry cloth towel.
Step 10. Apply steam heat from steam iron set at low steam setting (approximately mid range) in 15-second intervals.
Step 11. Check progress periodically by peeking under towel.
Step 12. Remove heat when stain is gone or if carpet color loss is observed.
BUT as Ofer mentioned you might consider sectioning out the stain and replacing with carpet from the closet. It should be an easy fix with that type of construction. The black polish on white may not come out completely.
Yeah I am fairly sure I could get it out using pro choice gels.
It was still pretty bad when I was done. Luckily it was in the master closet. I cleaned several apartments after her so was able to leave some fans behind to promote drying. She dropped them off with a check @ an hour ago and said she was very happy despite the limited success with the nail polish. It's all about managing those expectations. Thanks for the help guys.
The Clean Machine
Ive been cleaning since 1999 I still cant get paint out. It shows you how shady all the distributors and chemical sales people are. They all sell paint removers and none of them work. Trust me Ive tried them all.
Golden Boy
Golden Boy
Did I miss the after picture?
Golden Boy
Golden Boy
Saiger" data-source="post: 4253825" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Seriously the best paint remover we have found! I have passed this on to other local cleaners in the area as well. It is a bit spendy, but it works and will go a long way. We will never be without it at this point.
Quest Graffiti Gone in a spray can
I was embarrassed and ashamed at the results ;-).
The Clean Machine
Golden Boy
