Box Truck ?Pine? Floors?
rwcarpet
Robert Hodge
If you have bought a new or used box truck with wooden floors, I think yellow pine, what would you treat it with? Bed liner? Carpet? Any ideas?
Yes we got a new box truck this fall and had bedliner sprayed on the wood floor and the rear bumper.
Reactions: rwcarpet
They do look nice when new. The bedliner keeps the wood from getting damaged from water leaks and isn't as slippery too.
It would be worth figuring out what the wood is. If plywood it might be a softwood and should be coated. I'd also coat an old oak floor, but I think all the newer floors are tropical hardwoods like apatong that don't need much care at all.
C
C&S
the new tanks have nuts rotomolded into the plastic so that the water transfer pump bolts right on.
Reactions: TimM
M
Mike Draper
My box truck has wood floors. I covered it in an heavy indoor/ outdoor carpet with a rubber backing. It's holding up great.
Ron Werner
Ron Werner
I applied Seal Once to the plywood I'm putting on the floor, then I'll be covering it with G-Floor and sealing the edges
