Demi Valve again
GCCLee
East TN
C. Lee
So, since ya'll decided to have a sprayer pow wow not long ago. I just wanted to let you all know your buttheads for it.
My question is this.
I replaced the whole block w a new one and it is still back filling. Would a bad Male QC on the HF cause this issue?
And how the hell you get the water nozzle out. I destroyed the 807 washer trying to get to it. There must be a trick.
I must master these blocks, they supply the juices to my masterpieces!
TimM
Ogden, Utah
Tim Magaw
if the jug is filling up, the problem is the ball bearing and the spring on the draw tube. I can not find a picture to show it, but on the draw tube were it connects to the dema valve, there is a spring and ball bearing in there that prevents water from back filling the jug.
TimM
Ogden, Utah
Tim Magaw
[video=youtube_share;gFBS18ECe70]http://youtu.be/gFBS18ECe70[/video]
GCCLee
East TN
C. Lee
Man I really feel stupit : )
Forgot the O ring!
Thanks Tim!
Reactions: TimM
GCCLee
East TN
C. Lee
Sumbeech
Tried it on a job this afternoon, after fookin w it.
Still backfills!
This is a new Block and guts.
Bawb says why the hell you pre spray , somethin about star wars then to run it over wit the truck or stretch the spring and im thinking oh my wtf
Man these sprayers are nice but what a pain. Ya get used to em then blam.
N GA
BradFenstermaker
Mike put up a YouTube vid not long ago on changing the meter tip.
Think he replaced guts to. See if you can search. I am on dumb smart phone or I wood
floorguy
Utah
Doug
put a video up showing the setup and watching it back fill.....
GCCLee
East TN
C. Lee
Its snowing. When the porty gets here thurs it will be easier to work on, so I will try then. Worked on them a little last night but it was way too late to fire up the Genie so...
La La Land
ahh Chris.....i wonder if the manufacturer TESTS those portys at the factory.......
THEN ships them across below 0 areas in the back of a cold assed truck...
jus sumthin for ya ta think about...............
either they are untested OR theres a little water in them..WOW!
GCCLee
East TN
C. Lee
WARRANTY BAWB : )
GCCLee
East TN
C. Lee
ahh Chris....what would my lif be lik if i couldn't f*** wit ya .....a little?
Remove the handle!
Inside the block, in front of the water nozzle is a thick gray plastic looking washer as shown on the white towel.
Also stretched the spring out under the ball. Replace the Ball O ring aswell.
All user repairable with a few cheap parts.
So ya wanna chat some more about this emulsification process Bawb?
floorguy
Utah
Doug
wow....very odd....
the funny thing is on my older one...i dont think i have the o-rings, except that little 1....
that damn thing should not be able to bypass...
what psi are you running??? i probably missed it
La La Land
ya Chris...i AM about ready to start a pre-spray VS emulsification thread up here real soon.....
cuz i do believe that anyone who pre-sprays is wrong...and i can prove it!
so gentlemen start yor engines.......
GCCLee
East TN
C. Lee
wow....very odd....
Never said, but 500psi
