SOME HEATER HELP PLEASE
so i got this Dayton Infared 60,000 BTU heater in my shop....(yea way too big for a small garage) well it has worked great for 4 years now.....but the igniter has went out....so i got this one from Graingers......
http://www.grainger.com/product/DAYTON-Three-Prong-Electrode-1FEK9?searchQuery=1fek9
it's a three prong...i see one prong but the other two MUST be under the red rubber boot.......
the dang rubber boot will NOT come off....i've pulled on it so hard i'm afraid it'll break....
anyone ever put one of these on......?
thanks
That's it...i've been searching for this for two weeks now.....
no i havn't got the old one off yet...it requires getting up on a ladder
which i USED to be able to do easily........now it ain't so easy..
thanks Frank......
this place is great!
Reactions: Mark Saiger
G
GCCLee
Get some help so you don have to elevate yourself : )
U Have an Air Plane to catch homie!
thanks Dan.....that's it for sure...but the red rubber boot WILL NOT slip off .....i KNOW it has to come off to even get close to the other two spades inside...
crap i hope it's not the module:evil:
D
dgardner
There's only one terminal inside the boot. The third prong refers to the electrode that's spot-welded to the mounting bracket. No need to pull the boot off - the heavily insulated orange high-voltage wire (think spark plug wire) goes there.
i already have the part..
there is just the boot with a small hole in the end for a wire to come out...looks lik it HAS to come off in order to attach to the spade inside......what am i missing here?
OK..now i have climbed up where i can see the big red wire......
are you saying to jus pull it outta the red boot?
G
GCCLee
On the ladder yanking the lil red booty, you cannot go out like this Bawb.
Hey, did ya atleast lick yur fingers first : )
G
GCCLee
can ya get a lil flat hed in there to help lift.
also as you know Sometimes turning things like that will help break it loose.
Bob, I told you LAST WEEK to quit obsessing about that damn rubber boot .
it ain't a starter or alternator wiring harness :icon_rolleyes:
KevinD
Kevin Dumas
I sure you have a spark plug boot removal tool in that garage.
Bob;
As Dan mentioned;
There is only one high voltage spark ignition wire that goes into the red boot.
It may snap in like a distributor connection on a car.
I have also seen some connections that require the high voltage wire to screw in,
but that is less likely.
Larry
thanks guys...the picture of them red wires made everything come into focus....
now i jus gotta climb up there.......Mikey is gonna be sooooooo pissed if i break my nek......
i wonder if airline tickets are refundable......
G
GCCLee
Should we go ahead and call the Police, he's been on that ladder for 4 hours now : )
naw...im gonna work on it tomorrow.....
gotta WARM up the garage first.......
jus hit the circuit breaker and lite it wit a long bic lighter.......
i'll let yous know.....and again thanks for all the help
theres some fart smellas on here!
Goomer
Frank Mendo
With your vast experience working in HIGH places, you should do just fine.
naw...i jus flip the circuit breaker an lit it wit a long bic lighter for now......
haven't had anything going out there lately...
