How are your jets=not football
jack zerkie
How long do your jets last. I use stainless jets. Do you use the screens for the jets and how often do you clean the jets and screens. I have been having a problem with the jets not spraying even due to a blockage in the jet. I do clean them with a dental tool.Just wondered how common it is for you ? jz.
Billy
BH
I used to have to clean screens & jets frequently but since changing all hoses out to Stainless we haven't had any issues. No blockages at all which was an unexpected surprise for us.
Changing hoses to stainless was very expensive but worth it.
don't waste your time with jet screens....jet check valves...or regular check valves...jet screens just distort your spray pattern.....and are a huge PITA when they get dirty.....
check valves have a low cracking pressure...if your wand valve leaks...they will still drip....
keep your wand healthy.......get a fine mesh filter for you wand valve...and be done with it....much easier and quicker to deal with if it gets clogged......
I agree with Jim, those internal check valves are horrible.
I much prefer the West pack extenders and an in line filter at the QC
Reactions: Bill Soukoreff
GCCLee
C. Lee
That's how we learned to run em.
From here : )
