B
bildung
Well, how did the clean off between the Aerotech/Zipper and Rick G's Lowboy go?
I also spilled about a gallon of encap liquid. When I tilted the cimex back like a doofus.
Isn't that an OLD Oreck Low boy?
Put some bigger wheels on the back.................sheeeeez.
That bar very crowded!
We should have stayed off it after we cleaned it but while still wet we were all walking in and out throughout the day going to the bar or just cutting through the room.![]()
Those large wheels really helped make it run smooth. Hard to beat the price as an intro into VLM or to add to your fleet as an extra unit.
I also like the spotting approach that Rick suggested with the brush roller thing, during his presentation. I need to order a couple of those tools. Why bring a machine up when that spotter brush will do. Plus on maintenance contacts while one tech is using the machine someone else could be touching up otherwise clean areas. Thanks for the tip Rick!![]()
Ricks wife did go over all of the carpet with the CRB prior to vacuuming the bar but I don't believe it was used as stand alone??? But I was in and out of there, it was so crowded in there.Did the BrushPro also get tested ? ?
They are good at digging up soil.
You had a new one to compare.
Proper Testing is more difficult than it seems.
Larry
Yes sir that's it Zee! Do you use it for spotting?I pulled it out to take a picture of what I have in my van as far as zebra goes.
Is this what you're talking about Doc?
