V pto shaft is toast
back in October I had the pillow blacks and U joints replaced, three years or so the fitst yoke off the pto blew apart (not getting lubed by my chimp) and now the spline shaft is bent so while their at it I'm replacing the all yokes before she blows...
https://www.youtube.com/watch?v=buoGIOTzp5E
Not sure how it got bent, could be one of the transmission goobers dropped it or possibly when the 1st yoke blew apart but I would have though the noise and bouncing that showed up yesterday would have reared it's ugly head a lot sooner.
$250 in parts, 2.5 hours labor.
Found a great pto supply place down in Salinas that had everything (5 pieces) in stock and loads of knowledge and I'm blessed to have a local machine and fabrication shop to fix it all. Farm gear is their specialty so the POS Vortex is nothing special
Wow first how the heck did that get bent even slightly?
Did it tear up any other bearings?
What all did you replace
That's what happened to mine....the yoke strap broke........
But mine was running full load....and when it let lose it was Armageddon...
it was not so bad the PTO shaft took off like a missile and exploded...but shrapnel went through the transmission pan and it was game over from there.....
I think it was this part that took out the tranny....found it resting by the tire......
I ordered another complete PTO shaft from A/T and replaced it myself...
But she had to be towed to a repair shop to have the pan pulled and the hole welded back up........
G
GCCLee
Dang Mikey,
An double Dang Jim,
Having a local shop or garage that can help work on this stuff is super handy. Plus the good ones will usually provide priceless tips.
How much that cost ya total Martin?
Chris..wadn't you that bought one of my spares for a hunnert bukz....?
G
GCCLee
Totally different equip Bawb. Wr would have a belt snap before a grenade scenario like these guys went through.
An it was $400 azzholio : )
Reactions: Jimbo
Dang Mikey,
An double Dang Jim,
I don't remember....this was abut 5 years ago..(?)..
If it was not for it hitting the pan and punching a hole in it....I could of just strapped the PTO shaft up to the side and drove it home and fixed it...
the tow bill was high because of the size truck they had to send out...then the cost to fix the pan....
G
GCCLee
Dang man,
Is there a place to put a shield in there? 4 bolts is better than a tow any day!
Dang man,
not really...and the way this thing came UN-glued....even if there was a holding strap to catch the shaft.....it would not of stopped all those flying parts........
G
GCCLee
Sharpies are fun, kinda like crayons with a buzz : )
I'm having two straps installed but the key is replacing the U joints every busy year or so.
And lots of grease..
Reactions: dealtimeman
I know I busted your vacuum, but I didn't think I had enough time on the V to break that too!
I can be hard on some equipment sometimes.
Old Racing habit....run it like ya stole it!
Mark
Reactions: GCCLee
when I brought mine home from MN it still had that stupid shield under it and when I removed it...I found those front bearing that were hidden up in there and they were worn out....
Those were one of the first of many things I fixed on that truck....I always keep them heavily greased....the only thing I can figure on that yoke..was that the MN salt might of gotten to it and weakened the holding strap...
I am just glad no one was standing around the truck when it let lose......parts went everywhere..........
I really liked that truck...........but I would be lying if I said I missed it...........it was always something
that WAS my tongue in cheek comment......azzholio : )
