Upholstery question
Russ T.
Slater, IA
Russ Terhaar
I would think that simply prespraying with a good fabric prespray, allowing a little dwell time, and then flushing with a higher flow tool like the DriMaster or Sapphire would do the trick. No?
The Clean Machine
Arizona
Micro fiber is a lot more durable them most think it is....
the best pre spray mix for UPH that I have used on just about everything with out a single issue is....
1 gallon warm water...
2 oz of boost all
8 oz of fabric shampoo
2 oz of citric
Just adjust the mix to what ever size sprayer you are using....
spray it on and take a brush and work it in some and with a little heat...it will clean it up with no problem...
works every time..........
Reactions: J Scott W
Used Flex powder on the microfiber. They had Stanley clean it last time and the hardened febreez area did not budge. Turned out great. Also removed some ink with q tips and solvent. Flex got the remainder out. Normally I use fine fabric. Decided to try something stronger. Cleaned up great.
GCCLee
East TN
C. Lee
Judson O2 no hot sauce.
I hate that rinse but ya gotta use it, I guess ?
Do not let it sit in an extra tank you use once in a while.
Only Mix what ya need!
Goes bad and is flat Rank in the truck. Bionic Pond water, lol
Boca Raton
I can't believe somebody cleaned it and it didn't come out. Febreeze just rinses right out. I had a chenille hard as a rock and it just came right out. What's Stanley steamer cleaning with.
I carry the shampoo but rarely use it. To hard to rinse, I prefer fabric prespray
Gene
Good thing you used a Qtip... Some solvents can still cause delamination of the glue and fabric...
glenboy
MACOMB MI
GLEN
I hit microjunk with an enzyme powerburst.and then fab pros uph pre spray agitate and rinse the nastiness out
Sent from my SAMSUNG-SM-N900A using Tapatalk
