You used the wrong pad
You used the wrong juice
You should have mode more passes
You didn't pre vacuum enough
It would have all came out in the post vacuum
Your heart was just not into it
You just don't understand
What else will those lying dopes say?
Hate to tell you this Todd,m but if you have run an RE over it it would have looked even better.
But thanks for that great, truthful and morally wonderful video!!
~God on Mikey's PC.
Same handle. If you watch closely @ 2:48 you can see the wheel bolt get rattled out and swept onto the hardwood floor. The sprayer wasn't working ( not drawing chemicals )
wth ran G off....anyway.................?
The only real debate is how straight of a face can you keep when you show them the non rinsed areas and claim you're done?
I've got to give you credit Mardie. I thought you were going to say smoke and mirrors or photo shopped.Mikey I would like to know how you keep straight face playing along with Todds farce ? Given Todds past and present personal obsession with trying to discredit this machine how could you give credibility to his video ? Knowing how this machine performs I would say Todds pre-spray consisted of nothing more than water. Then Todd pre-sprayed it properly before the hwe part of the cleaning. I personally would not believe a thing Todd says in regards to the Trinity.
WATER it wouldn't have cleaned as well as it did with water. Even the yellow stain came out with OP.
You're over thinking it. No conspiracy theories needed. Just try it for yourself.
Ohhh can I have your Rock after you slit your wrists?![]()
