Clean yours lately?
C&S
Scott
I was very surprised to see this much crap built up.
Sent from my HTC6435LVW using Tapatalk
Slide open the vent and use a pair of tweezers. It only takes about a minute. No disassembly needed.
gene
C&S
Scott
There is no way you could have removed that much stuff with players threw the vent, it was wrapped up pretty bad, besides they are ment to be taken apart easily.
GCCLee
C. Lee
That lil supply tube.
I accidentally blew 600psi through it an it survived : )
Whoops!
C&S
Scott
What are they rated for psi?
Becker
Becker
That little supply tube does not retain pressure and the manifold offers a lot of flow.
It does not take long to take it apart for a proper cleaning, I was amazed with the crap stuck in mine, still worked great. Not sure I'd be able to clean it though the vent. Or at least in a timely manner.
Doug Cox
Doug Cox
yep- Get used to to cleaning it out on a regular basis
C&S
Scott
Aroundtheworld. What does dryer vent cleaning have to do with crap building up in the ss upholstery tool?
I did it and there was that much. I use the same tweezers on my zippers and pull out way more through much smaller holes. Don't knock it till to try it
gene
