New Westpak Titanium & Prochem Titanium wand comparison
Prochem Titanium and New Westpak Titanium.
Nothing Scientific....just in one of the garages with some dirty carpet samples,.
Prespray only, no prevac, no agitation....just the family getting together.
What we found in our fun
1) the Westpak titanium is a bit shorter and maybe a bit heavier than the Prochem (we did not weigh them, just going by feel)
2) We had Hybrid glides on both, the Prochem had a newer glide.
3) The Prochem had six 11002 Jets for 12 flow, the Westpak has 4 jets and we had 11002 jets in for 8 flow.
4) We found the height from the bottom of the jets to the floor (or carpet) to be about the same in distance which was right around 1 inch to the hard surface floor. The Prochem had 1 inch check valve extenders and the Westpak had half inch extenders .
5) We would have liked to have tried 11003 jets in the Westpak as it might have had some streaking or distortion with the .02 jets and we think the impact from .03 jest (and 12 flow) would have helped it. We did not have .03 jets to test (but we did have beer!)
6) We were running a High Heat Butler on high setting with 25 feet of 2.5 inch hose, to 50 feet of 2 inch hose. Water pressure was at 500 PSI which has been a sweet spot for our Butlers and current wand set ups. That pressure might have been a little high for the Westpak on some carpet, but again, the .03 jets could help (or dialing down the pressure).
The Westpak Titanium is a good wand for the price and it will come down to preference and price point for some.
Keep in mind, if taller, the Westpak might be a bit short for you, but could be comfortable for many.
I use the Prochem Titanium all the time and did not find the switch back and forth really noticeable.
Again, no science involved here….Just some fun and trying to find some sweet spots for the new Westpak….
www.saigers.com
"Bring on the Blue"!
D
dgardner
Great demo! Looked like the Westpak oversprayed noticeably off the sides?
Noble Carpet Cleaners
I guess what I'd like to know is the weight difference on the WestPack standard vs their "titanium" but decked out with glide and check valves? I've been swinging their standard for couple years now, wondering if even 1/2lb or more will help my shoulder?
TConway
Thomas Conway
Looking at the WP the weld are a little goopy.
The other thing I notice is the jet manifolds on PC and WP look the the same length....I would take them off the wp and tap a hole in the manifold right in the center and turn it into a six jet right off the bat. Doing so may allow total different jets and stop that little over spray
I have been been doing some wand test myself
TConway
Thomas Conway
Turning the WP into a 6 jet you would be able to get rid of the 110 spray and maybe go to 95 and get a little better impact.
Thanks for taking the time to do the side-by-side cleaning . . .
Westpak put the spacer back in the 14" Ti, which it needed, but it did still have some clean streaking under the jets (and some overspray) .
On the PC Titanium, the glide left some lines which should rake out.
Both of the 2" wands need a Mytee Wand handle as a mod.
Both of the 2" wands need a Mytee Wand (MY20S) handle as a mod.
(New BB wouldn't let me post a photo or a link ? )
Error Message
Larry
Reactions: Mark Saiger
Until you learn how to speak proper English, the way we do down here, you should use your hands more.
Structural Plastic Wand Handle Photo :
Thanks Dan,
Larry
LOL..datz funny
do us north of the Mason-Dixon get lessons from you, or Fentsermaker?
If you can stand talking to Fensterfocker over the phone, I suggest you go to him.
I'm too busy teaching Fred how to be pleasant with people.
