adamh
- Oct 7, 2006
- 1,533
- Name
- Adam Hale
I have a problem with this Powerclean unit that I cant figure out. What is the number of a Powerclean guru?
thanks
thanks
Hold the phone closer to the spot and I'll be able to tell you what it is
The problem is this.
After this thing heats up, if you put the wand down for a little bit the pressure starts to climb. It will go from 500 psi to 2000 psi in about 1 min.
I have changed the temp sensors, and the pressure regulator.
I have checked and rechecked everything. .....
Yup. The service manual pdf I have has nothing.No one has a plumbing diagram on the genesis.
