dgardner
"I'm moving side to side so dad can see it all" How cute!
4th job today.........
I didn't know cows ate cactus !!! I only see them in grassy pastureshe got a bit close to the cactus..if the farmer does not get those out they will get all infected......
Boy sorry to hear this.... I think what would be best is to get a good vacuum and prevac every thing and drop the Dev in the winter months if it is that cold. This is out of my control.Have been using a regular cuff to my Devastator but it's COLD and the D freezes up and restricts airflow.
By yourself or with a helper?
Saiger" data-source="post: 4323604" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Hey Russ,
Would you be able to run the D inside the van?
I have seen that done also.
With our Butlers, our filter system is in the back of the van inside.
Not sure what your set up is, but if you have room to run it inside, I would do that for sure.
Need to keep that warm as that is a focal point of a lot of turbulence and cold air.
I have had my filter system even inside the van freeze up a couple times (was a crazy water extraction job, was even freezing the bottom of the water claw)
Looking forward to seeing pics of your set up.
