Dynachem Used Truckmounts - Only Have 3
Received from Restoration Contractor - Low Hours, Maintained by Cobb
1 . . DC534 - 34 HP Kohler with #4 Blower, Stainless Heat Exchanger, General Pump System, 100 Gal. Recovery Tank, 75 Gal Fresh Water, Only 610 hrs.
- $6099 Machine Only
2 . . DC534 - 34 HP Kohler with #4 Blower, Stainless Heat Exchanger, General Pump System, 100 Gal. Recovery Tank, 75 Gal Fresh Water - $5299 Machine Only
3 . . DC410 - 27 HP Kohler with #4 Blower, Stainless Heat Exchanger, General Pump System, 100 Gal. Recovery Tank, 75 Gal Fresh Water - $5099 Machine Only
Larry
adamh
Adam Hale
I finally pull the trigger on a back up unit and then you go and do this...........crap!!!! that is the machine I wanted
bummer ..
(I say that cause I presume some resto contractor went belly-up)
or heaven forbid , they had so many headaches with the Garage-o-matics you had to eat them :eekk:
Since Judson can afford to give away used units every year, how about we auction one off?
Tickets can cost $1.00 and all the proceeds can go to getting Ray up to date on his rabies shots and get him fixed.
or the charity of your choice.
Lee;
As Jesse mentioned . . . we like the Sutorbilt 4MP blowers on all of these units, since they are capable of higher lift than the #47 . . .
We do have TM's with #5MR Sutorbilts . . .
P.S. Contractor is doing just fine .
Larry, are you still operating a smoke-belching PowerMatic ?
Nothing like the sweet smell of Kerosene
in the morning . . .
We built some Diesel-powered Transfer-Case PTOs . . . 20 years ago .
rick imby
Rick
Machine only?
Why do you state the tank size if they are not included?
Or are the tanks included just not hoses, wand, installation?
come'on ,Lar
who gets rid of three low hour TMs if they're "doing fine"?
the same type contractor who says "the only reason" for selling his 1000 hr TM it cause it's easier/faster to buy a new TM (presumably different brand) than to replace a cooked motor????:lol:
uh huh...
At that price I don't see how you could lose on any of them. Great back up or as an add on unit in the spring.
Reactions: Russ T.
The one I have seen had a lot of new parts on it along with all new hoses.
I don't how many hours the one I saw had on it just that it had a LOT of new parts on it.
I doubt they froze because there is only maybe 3-4 days a year (at least where I live) that it gets cold enough to give us a hard freeze.
Does Michael work?
Or is he renting Larry's back yard shack?
Ofer I know how to work, I have seen a lot of YouTube videos to show me how others do it. The day it comes down to it I am sure I will know how to do it.
I knew that Michael.
Just technically curious as to how you manage to keep so updated on Larry's inventory?
Is it the shack?
Crazy Ray?
Osmosis?
:winky: ?
